![]() | Home > Technical (L322) > 2007 TDV8 gas pedal response. |
DaveAngel Member Since: 15 Aug 2011 Location: Cowplain, UK Posts: 205 ![]() ![]() |
There is a around half a second turbo lag coming from low revs before the first turbo spins up, once it has, seams fine, could that be what you are experiencing?
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
I get exactly the same feel in my 2006 4.2sc and have been wondering if something is wrong, i will watch this thread with interest. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
The throttle linkage is electronic. The pedal is basically a big potentiometer which may be faulty. Though as said above coming from a petrol car to a big TD will introduce a bit of throttle lag from standstill. There is nothing that can't be fixed with a hammer😜😜
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
I can relate to this......my 2006 SC throttle is very sensitive. If I need to accelerate from say a slow speed and just want to do so gently there feels like there is literally mm in the throttle required. Any more than that and all hell is let loose, kicks down etc. and you're off. It is a bit tiring and I have wondered whether there is any kid of throttle body that needs cleaning. It sounds like I am not alone! 2006 4.2 SC
