Home > Technical (L322) > Lambda/Oxygen Sensors
georgedb
South Africa 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Is there no permanent cure for the Lambda sensors on the 4.2 SC.
cannot see how a person can be replacing these every 3 months when they go and cause EMS faults.
Post #340217 1st Aug 2015 8:10am
dingg1
they should last for about 70,000 miles without needing to be changed out
Post #340223 1st Aug 2015 9:08am
make sure you/they fit genuine or OEM, there are cheap pattern ones out there that don't last... Pete
Post #340245 1st Aug 2015 11:43am
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
Why do you need to replace it so often - are there error codes that indicate that and what are the symptoms
Post #340247 1st Aug 2015 12:16pm
georgedb
@ Haylands: Thanks. I think here in SA you can only get them from LRSA.
@VNitos: New sensors were put in 4 months ago. Then last Saturday going onto the freeway the EMS light came on. Disconnected the battery and light stayed off till Tuesday. Fault was cleared on Thursday through diag tool but appeared again Friday AM. Rough lumpy idle when light is present.
This AM when I pulled the RR out you could also smell fuel. Had the error codes read this PM and comes up with P0137 and P0430.
Post #340289 1st Aug 2015 4:34pm
Zirconblue
It depends what is killing the sensors.
Is the exhaust in good condition? No leaks? Are the catalylic converters working ok?
Post #340291 1st Aug 2015 4:39pm
georgedb
@ Zirconblue: Will have to have to exhaust system looked at for leaks then as you say the cats.
Post #340292 1st Aug 2015 4:44pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Assuming 2 lambda sensors, are they both the same part number, if so, you could try swapping them over. I had an issue on another car once with them and it was simply a poor connection on one of them. On that car,no feedback from a sensor defaulted to 100% oxygen and so the ECU was basically assuming at least 50% flow all the time causing the car to run 'rich' on fuel (as I'm told the ECUs used to just take the readings from the 2 sensors and divided it by 2 to get the average oxygen flow rate - they may be more advanced now though). So basically , if I disconnected them both completely, the ECU assumed 100% (2 x100 / 2) air flow and the engine would run very very rich. May be worth checking the connection pins. LRs may work totally differently of course. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #340293 1st Aug 2015 4:45pm
vnitos
@George. What error codes does it show when you plug the diagnostic tool in. Does these errors include "multiple misfires"? Is the car's engine performance reduced when the EMS light is on. Is the lumpy idle a misfire or not?
Reasons for my questions is that there is a known problem with the 4.2SC's auxiliary cooling (water) pump - LR connected the wires the wrong way round resulting in the pump turning the wrong way round with resultant failure of the pump.
I have a problem that when my car is idling the body shakes like it is misfiring. However the car always performed well. I removed the cats and replaced spark plugs which improved but not completely cured the problem. So I'm going to have the auxiliary water pump replaced within the next week or so.
If you pm me your email address then I can forward you the TSB that LR issued re the water pump problem
Post #340361 2nd Aug 2015 8:11am
georgedb
@Trev PM sent.
codes P0137 and P0430.
Idle is rough and lumpy with light on
there is the possibility of a missfire as the idle even with light out is not a continious humm but an up and down afair.
Post #340381 2nd Aug 2015 10:42am
georgedb
Update
So took the truck in to an Indie past Friday. They hooked up the more upmarket OBD tool and picked up a low voltage error on the rear sensor for bank 2. Swapped right to left and cleared all errors. So will monitor the new setup and see if error returns.
Post #341852 11th Aug 2015 3:47pm
vnitos
Did this also resolve the lumpy idling issue?
Post #341868 11th Aug 2015 6:11pm
georgedb
I would say yes; but did not drive too much this past weekend. But on startup yesterday; this AM and this arvie I did not notice any lumpyness or roughness on start-up at idle speed.
Post #341877 11th Aug 2015 6:51pm
