Home > Technical (L322) > DVD RSE problem
Chriscase200
England 2006 Range Rover Vogue SE Supercharged Java Black
DVD RSE problem
I have a problem with the DVD player on my 2006MY FFRR
I put some new discs in (all region 2 and not copies) and the DVD player goes through the loading process, but then i get a blue screen with 'Video Signal incorrect' or words to that effect.
Anybody else had the same problem and knows how to rectify it. FYI i have replaced the discs in the DVD magazine to the ones that i knew were working and still the same problem......also the TV is working so its not a screen issue so it appears to be just DVD. Range Rover Vogue 4.2 V8 Supercharged 2006MY
Post #31606 13th Oct 2010 2:36pm
Chriscase200
I solved the problem myself so i tought i'd answer it here in case anyone else has the same problem.
The DVD had inadvertantly been changed to NTSC from PAL.
The way to change it back easily is to use the remote control and press the power button and keep it pressed for about two or three seconds, you will then see NTSC or PAL come up on the screen (dependant on your region) then its just a matter pressing the power button again to change it to the desired video system.
The full instructions from Land Rover are here... http://www.rrsport.co.uk/gallery/albums/us...errors.pdf Range Rover Vogue 4.2 V8 Supercharged 2006MY
Post #31936 15th Oct 2010 8:26pm
