![]() | Home > Technical (L322) > bad fuel |
Mmmmmm, I would start looking at alternator/battery i.e. low voltage. First of all the fuel goes through a filter so crap should be unable from reaching the engine/injectors.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35852 ![]() ![]() |
if the dodgy fuel went though a filter, would not the filter be the problem.. ... - .- -.
Richards7 Member Since: 15 Sep 2014 Location: Cumbria Posts: 8 ![]() ![]() ![]() |
Hi
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Filters do not remove solds they just stop them from passing to the other side. The filter can block up with solids and severly restrict fuel flow.. I got limited gears etc on my SC the other week and had to clear it with IID Tool. I put it down to having the car sitting doing nothing for a couple of weeks and then doing a couple of short journeys which didn't give the battery chance to fully re-charge. No bother since! Previous cars:
Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128 ![]() ![]() ![]() |
I would agree with Stan first job change fuel filter make share all the old heating oil ( red deisel) is cleaned out of system .if any trace is found in tank you will have some explaining to do . if stopped for roadside check |
I have just checked the voltage and with the engine running I have 13.8v across the terminals. I have checked the fuel flow at the return and it seems OK. I have drained the fuel filter and again seems OK.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8785 ![]() ![]() ![]() |
I think you could be right on the fuel front, the codes suggest a fuel problem, P1623 is an immobiliser timeout code so probably not related, P117D is a fuel volume control valve exceeds maximum code, and rave says:
I would still change the fuel filter first & try a couple of bottles of fuel system cleaner in tank or pour one direct into new fuel filter before you fit it they way it goes straight to fuel injectors as you crank engine over . Anything is worth a try before heading to main dealer ££££££ |
this is excellent help thanks so much for trying to explain. I will let you know.. |
Bad news now...
Blademaster Member Since: 04 Aug 2015 Location: Warwickshire Posts: 2 ![]() ![]() ![]() |
Hi,
interesting, i gather you are knowledgeable about this kind of thing.. ... - .- -.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Given the location of Warwickshire i wonder if Mr (or Ms) Blademaster works for JLR. |
I don't work for JLR........although I can nearly see the place!
