![]() | Home > Technical (L322) > 2011 TDV8 4.4 juddering issue |
| PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877
Steve, would it be an idea to get another garage to take a look, fresh eyes and ears????
| Sh55123 Member Since: 31 Dec 2012 Location: Surrey Posts: 7
My MD is Harwoods of Croydon - not impressed either, and I too thought that the main dealer extended warranty would cover investigation work, but they tell me not.
Ryan from LR customer relations will investigate the claim for you.
| rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296
if your cars under warranty ,you shouldn't pay a penny ,I'd be livid.
| Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435
Sounds a bit like a torque converter issue.
Thanks for the tips gents - hugely appreciated! I will look up Ryan and contact him as you suggest.
I suspected torque converter shudder too, but was hoping they might have suggested that too.
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2777
Any chance that the park brake is sticking, possibly being out of adjustment? |
I suspected that too, but it doesn't do it while coasting in either forward or reverse when in neutral. I have tried at various speeds, and no sign of it when in neutral, all the way to slowing gradually to a stop on a flat surface. |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Brake caliper sticking (rears usually) could also be a problem. Easy to diagnose by feeling the wheels after a short drive. The wheel with the sticking caliper will be hotter. Since it has been going for a while (if it is a caliper) the bearings may now also have overheated a few times.
I don't think it can be brake related, as it does it in reverse when stone cold, and doesn't do it at all in neutral.
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
I thought that my torque converter was on it's way out again, even though it was only 14 k old, it has turned out to be 2 half dead injectors, mine only really showed up under gentle driving conditions, and the full on performance was not affected in the slightest.
Try this
FYI warranty will normally cover mechanical brakedowns, and not ware and tare, which is what I suspect the dealer is hoping for. Ie if it brakes they will replace it, but if it wares out then it's down to you. I would talk to your local Bosch agent, as the shuddering that your describing sounds very familiar to me, and even if it's not the engine, I'd rather pay the £65 per hour than stealers prices. And bare in mind that if your injectors are bad the stealer will only replace the with new, at LR prices, I bet that you can get all the injectors cleaned, test and repaired (if needed) for the cost of one injector from LR and have change |
| All times are GMT |
