Home > Technical (L322) > FBH Remote Issues
proser
FBH Remote Issues
Tried to sync the existing remote but no joy, therefore purchased a newer style remote from Ebay which was listed as new but gone through the sync process but still no joy.
I know the FBH works as I have started it through the touch screen
the sync process I followed was - pull lead out of the unit hat sits behind the fuse box in the boot, wait 30secs, plug back in and press the off button on the remote at the same time.
Any pointers ?? Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #342249 13th Aug 2015 2:54pm
Zirconblue
I took me a couple of goes to get it to take.
When you say newer style remote, do you men the L405 style one with 'Range Rover' on it? I tried one of those and it wouldn't work at all.
Post #342254 13th Aug 2015 3:46pm
proser
Thanks, looks like I got the wrong one - at least I didn't pay a lot for it. Regards
Mark
2012 Westminster
Post #342255 13th Aug 2015 3:47pm
Zirconblue
Those L405 ones are £250 from Land-Rover!
I stuck mine back on ebay with a better description, pointing out what they cost from Land Rover dealers. I think they also fit the newer Range Rover sport and D4. I got £40 for mine (only paid £25!)
Post #342256 13th Aug 2015 3:53pm
proser
Thumbs Up will do the same as only paid £14 for mine Very Happy Regards
Mark
2012 Westminster
Post #342257 13th Aug 2015 3:54pm
Discotigger
Try replacing the battery in your existing remote, sometimes an older battery doesn't have the juice left to send a clear sync signal through to the receiver.
Worked with mine when I had a similar problem.
Post #342406 14th Aug 2015 10:44am
proser
Thanks - that was this first thing that i did Thumbs Up Regards
Mark
2012 Westminster
Post #342415 14th Aug 2015 10:55am
Is it definitely a problem with the remote - does the heater work OK when switched on manually ?
I thought it needed a minimum temperature to operate ?
Post #342419 14th Aug 2015 10:58am
Mudplugger
England 2016 Range Rover Vogue SE SDV8 Waitomo Grey
Think you are right Alistair - the temp has to be at 6 deg C or less before the thing will start if my memory serves me.. Range Rover Vogue SE SDV8 - L405 (now sadly sold)
BMW i3 (fantastic little runabout)
Kioti NX6010 Tractor
Yamaha Big Bear ATV
And a whole heap of other kit...
Post #342437 14th Aug 2015 11:31am
Discotigger
You can also use the Remote to turn on the fans for ventilation/cooling when the temperature is higher than 6 Degrees. The LED on the remote shows green for ventilation and red for the FBH.
It may just be a case of trying the pairing procedure a few times, that's what I had to do to get mine sync'ed.
Post #342449 14th Aug 2015 12:09pm
proser
Works fine from the touchscreen
get nothing from the original remote, but I have got a T91 on it's way so will wait until that arrives before trying again.
Thanks for all the info so far. Thumbs Up Regards
Mark
2012 Westminster
Post #342453 14th Aug 2015 12:14pm
Proser i have a spare one if you want to pop up this weekend and try pairing it up?
Never had any issues with mine using the newer smaller T90 ones and the fuse removal technique Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #342480 14th Aug 2015 1:49pm
Zirconblue
Just to clarify here, I don't think there is an issue with the T90/T91 fobs.
But the L405 uses another different fob, which i couldn't get to pair with my L322 at all. The T91 i bought worked perfectly first time. It appears the L405 fob is incompatible with the receiver in the L322.
The T90 and 91 have "Land-Rover" on them. The L405 fob has "Range Rover" on it.
Post #342483 14th Aug 2015 1:56pm
they changed to a different webasto setup i believe at that point. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #342484 14th Aug 2015 1:59pm
proser
Kingpleb - whereabouts are you ?? Regards
Mark
2012 Westminster
Post #342485 14th Aug 2015 1:59pm
