![]() | Home > Technical (L322) > 'lambda control adaption exceeds lower limit' |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
I recon inlet manifold leak, has your PCV valve and associated pipework been changed (see WIKI) if not a leak somewhere else, even heard of the manifolds getting loose so check the nuts for tightness.... Pete
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 ![]() ![]() |
wouldnt an air leak cause it to exceed the upper limit?
Too much air and it runs lean.... Pete
Ok I thought the message meant that the lambda was trying to reduce the amount of fuel and exceeded the lower limit of adjustment but you're saying it's the opposite? |
Well that's my understanding of it..... Pete
Thanks for the help Pete. I have looked for leaks but found none.
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 ![]() ![]() |
Best thing is to check the live values from the MAF
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 ![]() ![]() ![]() |
If it's any help, I had that message for over a year. And 15,000 miles. If I cleared it, it would return the next day or two. The specialist said it was the K&N filter, then leaky injectors My local garage tried firstly the PCV pipes, then the fuel vent valve thingy then a lambda probe. Next was the MAF sensor which was changed - problem solved |
Thanks for the replies.
switched back to original maf because the pattern part had a smaller diameter and wouldn't seal on the intake hose. No probs for a few months but drove 12 hours yesterday and had the same prob on bank 2; live values: Idle 600rpm fluctuating between 21-25 1500 45 2000 70 Will put the pattern part in and update. Thanks for the help. 2004 L322 V8 |
