![]() | Home > General > exhausts and tow bar |
| nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2077
Doesn't look like a LR towbar so carn't comment.
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
I have a removable towbar but the sod is seized in. It took a fair amount of heating just to get the pin out, so I think I will have to take the bar off the vehicle to get the end out |
| Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181
John, it's a quite large armature that it's mounted into, you may need a helper with the weight of it, also you can download all the accessory fitting instructions from the Land Rover website as PDF documents - I assume that taking it off will be the backwards of putting it on!
Thanks for the link Tim, it isn't a difficult job to remove the towbar |
But the removable tow hook weighs about 15kgs! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Nothing compared to dropping a rear diff on the S-Class a few weeks ago |
You mean Mercs fail ........... |
Almost as bad as RR |
