| As Stan Posted above, but any 02-05 you can adjust all 3 heights separately too.
 Example,  you could have off road height set 10 mm higher than standard and access height set at -10 mm lower than standard, normal ride height can be set to anything you want, only thing you can't touch is motorway height as that lowers what you set normal height from.
 Any 06 model onwards can't do the above individually, so if off road height is 10 mm height than standard,  your normal and access height will be the same. ...10 mm higher .
 I knew their was a better reason getting an older model....
 Hope this helps too
  If it dont work.......burn it!
 If the IId tool cant fix it.......burn the FF.
 If the FF cant be fixed......buy a Land Cruiser!
 If the LC cant be fixed..............................................BUY a horse !!
