if you use some of this, 50mm steel box in 5mm thickness, 1 metre long at £18 http://www.ebay.co.uk/itm/Steel-Box-Sectio...259a6cb57b and fabricate any 'already made up' bike holder on to the steel, you are almost done.
if you use the 'bike frame crossbar' hanging type of bike mount, you sometimes find, that other guest bikes have odd shaped frames etc. however, if you use a wheel mounted rack like one above, you can fix 'any' bike to it.
you could use roof rail bike mounts, welded in parrallel to the hitch mount method, to fix your bikes to etc. -and hang a trailer board to stop the rear lights/reg plate being obscured etc.
