![]() | Home > Maintenance & Mods (L322) > Westfalia Towbar Removal and cleaning vinyl door cards |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35799 ![]() ![]() |
when you remove the towbar you need to re-fit the bumper bar ,smilier to this..
The bumper support bracket is just as heavy and almost as big , most people would say just remove the Westfalia receiver and get the plastic bung that goes in the square hole .
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8741 ![]() ![]() ![]() |
I have a cunning plan......
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
On the 2002 to 2005 models you also need the original hangers as the exhaust is hung from them. Not sure if that is the case with the 2007. John
Or pop by mine one weekend and do a swapsee with the standard units i could give you |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Same on 07 I think. I had to remove them to fit my towbar. Ed |
Which I have 😄😉 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
The towbar is a mission to remove by yourself, and you will need the brackets to replace the towbar so that your exhaust has some to hold on to, otherwise it will fall off |
The rubber bit is the only piece I don't have from the standard setup but they are only a few £ from Dan iirc.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
have a look on topix at the towbar installation instructions. Removing it is just the reverse of that. The crash bar is already there under the plastic bumper cover, the tow armature plates are held on by it. You will need the replacement towing eye/exhaust brackets though.
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
as stated above with the receiver removed ,bung in place and a pair of black electric socket covers ,
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
Thanks for the replies, 20 Magic sponges on order from Fleabay that will hopefully get the job done on the interior. Would you use these to get the grime of the leather aswell??
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
Stan, that pic is of a standard bumper reinforcer pal... Comes on all 322’s with or without tow bar... The towing eye brackets L & R is what the OP would need to replace ![]() |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3940 ![]() ![]() ![]() |
I am a bit puzzled by this thread, on my car when fitting a towbar, which I did my self after guidance from here, I didn't remove this bit just the two arms that hold the exhausts and such in place.
