![]() | Home > Technical (L322) > TDV8 Engine |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
Seen these advertise www.globalengines.co.uk Regards
Trantorman Member Since: 13 Oct 2012 Location: aberdeen Posts: 161 ![]() ![]() ![]() |
Mark,
Have you thought about asking a place like this to just give you a price for a straight swap if you turn up with the old engine as it must surely be a lot cheaper for them to do it this way?
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1849 ![]() ![]() |
That is very cheap |
It is indeed but if you can get the cost knocked down a load more for just a straight swap on the engine it could work out good. or maybe just see if they have 2 heads available and do that. Crank bearings are on the bay as well for £400 which is another good sign as they never used to be publicly available items or even to smaller business's. |
The E bay mob don't have any Engines in stock and the listing is indicative cost, when you talk to them the figures get much higher.
Good man |
