![]() | Home > Technical (L322) > Front suspension and ignorance |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
They do look a bit pathetic with no air in... can't remember about the band, is it the same as the other one?? the pushed in bit will soon come out when it's got air in... Pete
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
if you have a compressor to hand, blow it up and see .... ... - .- -.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
http://www.lrparts.net/air-spring-air-bag-...99999.html
Tom Paine Member Since: 11 May 2015 Location: Townsville Posts: 47 ![]() ![]() ![]() |
The left hand one looks perfect, with the ring square to the top of the whole thing. Perhaps a go with a compressor is the answer.
What make of bags are they ? There is Delfi OEM and Dunlop pattern ones . and the Dunlop bags aren't the same quality . 2008 MY Supercharged
They're Dunlop, and it's not the bag itself so much as the angle of the sealing? ring at the top
I think you know the answer , It's probably going to be a balls aicke but that has to go back in my opinion . 2008 MY Supercharged
Back to the UK unfortunately. Many more dollars. |
have you had both out and compared them to see if the metal band can be pushed into place.. ... - .- -.
Under UK consumer law, if you've been sold defective goods it's the retailers responsibility to pay return costs.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
correspond with the overseas supplier, they wont actually want it back, just tell them that it will cost them even more, in that they will be covering the return postage. if they get it back it has to go back to their supplier, maybe they can just get it replaced and sent direct, and you get to look after/dispose/sell the wonky one.
yep i'd agree with that. Some will insist on a return, but most will just write it off and claim the cost back from their supplier. If their supplier insists on a return, then they'll claim back the cost of returning it from them anyway. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
DONT WASTE YOUR TIME SIR!!! That is how they should look |
re Craigs post, i googled and found these pics...very much like you have..
