![]() | Home > Technical (L322) > Adaptive Headlights |
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 193 ![]() ![]() |
Hi Lost for words, I note that you have these LEDs in your disco, do you think they would be OK to fit in a 2011 RR vogue? |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Never really looked at those lights up close, but I assume they would phisically fit. Not sure if any electrical issues could occur or not in the FF - but resistors would sort that if needed (they're fine in the D3, but do trigger fault codes sometimes). Nice low current, and, for the earlier vehicle owners, would avoid the melting issue sometimes experienced. |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
The xenons in the FFRR have a different bulb than the D3.
Was with reference to the cornering lamp, but from what you say, the later ones have in-built LEDs for this (I'd assumed they were H8 from Cavalier's question)? Visiting from DISCO3.CO.UK
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
You don’t have halogen bulbs in a 2011 cornering light sir! They are LED’s already ![]() |
Apologies I thought the pic was a LED retrofitted in the main bulb area.
