Home > Technical (L322) > Steering wheel not tripping off
Hackweg
England 2005 Range Rover Vogue Td6 Java Black
I apologise if there as been other posts on this, but I could not find them.
I have found out what I thought was the splash screen not shutting off and causing a flat battery is in fact the steering wheel motor not stopping when it retracts when you exit the car.
Has anyone else had this problem and if so how do you fix it?
At the moment I just touch the adjuster for a nanosecond and this stops the motor from whirring .
All help appreciated
Thanks
Post #32287 18th Oct 2010 6:58pm
dont know why yours is doing that but i believe you can switch the steering column off so it doesnt move when you get in/out the car... ... - .- -.
Post #32290 18th Oct 2010 7:43pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Well, you're stuck to buying a new steering control CPU.
In the meantime, try this.
I had the same problem a while back and it was fixed under warranty. It involved a new control unit, but....even after that sometimes the wheel goes awol.
Usually this happens when the entrance procedure is not 100% correct. (WOW.... entrance procedures.... Rolling with laughter Rolling with laughter )
You have 2 keys, and each of them is assigned to a driver setting.
Put the steering in your position, but never all the way up or down, give it a bit of slack, maybe 1º. then memorize the setting. Get out, lock, unlock and get in, turn the key and it should work fine. Now, out again, 2nd key, program, out, in. It should be fine.
But here is the catch. With time, the wheel will vary a bit its position, use the binnacle as a reference. Mine (the memory setting) comes down maybe 2º per month. So once a month I put it back to my position and hit memory.
Then again, when moving between keys, sometimes the wheel will travel uncontrolled. Nver let it go to the end. The motor loses its 0 and can't get a refence position.
It can also go crazy when driver 1 uses memory 2 or vice versa, or when the position of the seats has been moved, maybe during servicing or washing.
So back to the procedure, let only 2 persons drive the car... Very Happy Very Happy
And when missus want to switch to driver side, lock the car and make her use her key to open it again. Meaning resetting all systems and memories.
Give it some tries.....
Post #32318 18th Oct 2010 9:26pm
