![]() | Home > Technical (L322) > TD6 GM auto box rebuilds |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
Agree 100%. I think you may be better going directly to a valve body specialist. There’s a couple of places here that you could ask :
reb78 Member Since: 06 Sep 2015 Location: Herts Posts: 55 ![]() ![]() |
Just out of interest, is it box off to get to the valve bodies on these? I only ask as I saw another post talkng about one of the V8 boxes, where it is mentioned that the valve body can be removed in situ. |
On all of the L322 transmissions the valve block assembly can be removed from underneath without the need for the transmission to come out.
sarn Member Since: 05 Apr 2013 Location: Oswestry,Shropshire Posts: 27 ![]() ![]() ![]() |
Thanks Phil I am in process of contacting companies you mentioned. Have also emailed Sonnax in the States. Will post as soon as I hear from them. There must be hundreds of folks out there who have unknowingly purchased rebuilt GM boxes that have not had this wear problem addressed! |
So if one were to buy one that had had a recent transmission change, if there was no evidence of the Sonnax kit being fitted, would it be worthwhile removing the valve block, modifying and replacing it and then flushing the system through? As Sarn says, there must be a large number of 'recon' boxes fitted that would not have had that mod? therefore if the replacement was recent, could this save further damage? |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Don't forget the tc is also a very weak point on the GM5L40E gearbox.
I guess My thinking was that there are a number of TD6 for sale that have had the gearbox and TC replaced. RRPhil mentioned on another thread that the TC will wear at an increased rate if the old valve bodies (either original box or recon) hadn't been replaced with the sonnax units, so if you were to whip out the valve body and finish off the job that the recon company perhaps should have done, before any major TC damage had occurred, then that might be a good move. |
Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128 ![]() ![]() ![]() |
Mackie in glasgow fit sonnex valves on gearbox rebuilds also replace torque converter |
Cheers Swiftman contacted Mackies of Glasgow and they quoted a price of £1500+carriage and vat. This means I will have to get old box removed and re built unit fitted at my local Independant LR garage.Am now looking into that. Great Website with loads of top class help available. For interest have owned 2002 TD6 Vogue for 6 years now, bought with 80000 on clock,now done 103000. Problems have been early front prop and diff failure (recall). New rad.+ air condenser , rear wiper mechanism repair.( last 3 repairs done at home) Air bag warning light - new body control ECU. Xmas lights on dash caused by broken wire from left rear wheel sensor. Service every year at home and use Castrol Edge in motor |
jemj Member Since: 13 Sep 2012 Location: leighton Buzzard Posts: 54 ![]() ![]() ![]() |
I had mine done in Luton 3 years ago. They change Torque Convertor and fit sonnax if after testing it is needed. Mine did and had full overhaul for £2300. I have clocked up another 63000 miles with a lot of towing and still going strong. The Best 4x4 by far, so long as you have deep pockets. |
