Home > Technical (L322) > Setting electric steering column into auto mode.
tvrforever
Did anybody get a definitive answer on this?
I've a MY2012 Westminster and there is no switch or rotate at all on the electric wheel adjuster stalk. The adjuster works perfectly when used manually.
I've checked the vehicle settings and it's enabled, and I have the current position stored in M1.
But the seat doesn't move or the wheel move on entry or exit Sad any clues?
Post #384585 30th Apr 2016 11:30am
DrRob
Old thread resurrected Whistle
How the f**k do I stop the seat and wheel moving on exit and entry?
Just want it to not move at all once set...
Is it only possible using a diagnostic tool like a Lynx or IID?
Cheers
Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #490048 26th Sep 2018 8:16pm
the iidtool can switch those off Rob..
Post #490049 26th Sep 2018 8:19pm
DrRob
Anyone in Hants got a pro IID? Whistle Bow down Wink Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #490050 26th Sep 2018 8:20pm
craig [cam tec] has but he's near dursley...
Post #490051 26th Sep 2018 8:22pm
rjff
Rob
Mine (MY11 4.4TDV8) has this option on the instrument panel menu. Not sure if it is set up on delivery or needs to be set up with an IID but I have just had a go. This has been the same since I purchased the car last October.
Right hand OK button on the wheel, brings up menu, scroll down to easy entry , enter OK and a tick should appear in the box and that should set up the seat and wheel to move to the lowest and highest position respectively for getting out. On re-entry, press engine start for the "ignition" and the wheel and seat move to your set memory positions.
Untick the easy entry box to stop the car doing this.
Trust this helps, but let us all know. I may be barking like a cat!! Cheers
Richard
Gap IIDBT
Post #490067 26th Sep 2018 9:40pm
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
yes, mine is a 2012 Westminster and works exactly how Richard says.... I need more help than most...sorry !!
Post #490089 27th Sep 2018 7:02am
Embarassed it is in the dash menu as well....
Post #490090 27th Sep 2018 7:14am
GGDR
At first I thought that was a cool feature but the novelty didn't last long!
Turned it off the next day.
. Cheers, Greg
Post #490091 27th Sep 2018 7:19am
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Me too! 2010 4.4 TDV8 Vogue SE
Post #490092 27th Sep 2018 7:39am
DrRob
Thanks folks! Will check it out at weekend. Muchos gracias Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #490115 27th Sep 2018 5:31pm
DrRob
Just to close this. It’s as described in replies above = uncheck the easy entry box on vehicle settings menu Bow down
PS I did RTFM but could not find it Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #490336 29th Sep 2018 5:59pm
