Home > Technical (L322) > L322 03 TD6
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
L322 03 TD6
Just got the RR back from Indy for new front struts and a injector ££££s and now the fan near gills on nearside stays on permanently!
Just had a new battery recently so don't want that to go below normal voltage. Have tried full power down and power up to no avail. What is this fan and any ideas please.
I just want a reliable car for Christmas 8-(
Post #348807 21st Sep 2015 6:51pm
sounds like the fbh running... ... - .- -.
Post #348810 21st Sep 2015 7:07pm
bleeperman
I don't think so Stan its from that plastic box behind the battery some sort of ECU...I don't think mine has a FBH fitted webasto thing yes? If so then not fitted.
Post #348927 22nd Sep 2015 3:14pm
so it doesnt power down at all?......i'd go back to the indy and let them sort it.. ... - .- -.
Post #348935 22nd Sep 2015 3:32pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Afaik all td6s came with fbh as standard, unless someone has removed it.
Post #348981 22nd Sep 2015 7:17pm
mjdronfield
Yes, all td6 have the FBH from factory. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #349007 22nd Sep 2015 9:12pm
He will have a FBH but in this instance I think the OP is referring to the cooling fan for the ECU's behind the battery. 2008 MY Supercharged
Post #349042 23rd Sep 2015 3:42am
Vikash
United Kingdom 2003 Range Rover Vogue Td6 Zambezi Silver
Re: L322 03 TD6
My 2003 TD6 hasn't been reliable for any Christmas Sad FF RR Vogue 2003 TD6
Post #349268 24th Sep 2015 12:54pm
