Home > Maintenance & Mods (L322) > Spark Plugs Stiff and Difficult to undo - SOLVED
Strider
Satisfying result Thumbs Up ,
Hope you had something a little stronger than a cuppa to celabrate, you earned it with your patience and determination Bow down
Post #349404 25th Sep 2015 7:54pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Thanks for your support guys - now I just hope plugs 7 and 8 are not in a similar state as they are more difficult to get to due to LPG pipework, fuel line and restriction due to side of engine bay.
In fairness only 6 was misfiring and I can see why in the plugs state when extracted. 7 & 8 were hopefully changed on last service. (Stan - there is no fingers crossed icon I can find for this.)
I gave up this afternoon on changing those as I considred I had probably exhausted my luck for one day and we have all been there thinking I will just finish off this last bit, should not take long then SNAP Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #349406 25th Sep 2015 7:57pm
SMUTT
@Strider - just taken 4 yr old daughter to the local fair ground - after the waltzers and loud music, and effort today (I know it is exaggeration but it felt a bit like bomb disposal) I just want my bed Yawn Howard
Post #349408 25th Sep 2015 7:59pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Well done SMUTT glad your sorted.
If my memory serves me correctly, wd 40 was invented by nasa for the rocket programme.
As normal oil and lubricants freeze easily in space wd40 was invented to combat the alien environment.
so I understand.
Anyway well done. Thumbs Up
greg. Bow down
Post #349409 25th Sep 2015 8:00pm
SMUTT
@gregdav - you may be confusing it with teflon ... or perhaps I am confused after today Howard
Post #349413 25th Sep 2015 8:13pm
gregdav
Naah, defo wd40, used to have rocket motif on can, may still do haven't looked recently.
Teflon invented for politicians and such like as nothing sticks Laughing Laughing Laughing Rolling with laughter Rolling with laughter Rolling with laughter
Post #349416 25th Sep 2015 8:26pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
johnboyairey wrote:
well done that man.... Very Happy
just a follow up, WD40..... the WD is 'Water Displacer' i think there is a rumour, that its mainly fish oil... but here.. https://en.wikipedia.org/wiki/WD-40 parhaps not.
i use it, here and there, but i have a can of some funny trade name stuff, that works, like plusgas.
often, with a seized bolt/nut, a few sprays and soaks, works, if not, then you can try sharp hammer blows, and resoaks, and finally localised high heat. all these are not really possible on spark plugs. so patience and afore-thought is the way forward. in all such instances, back and forth, is the way.
I am racked with guilt. Changed all my plugs last week and they all came out with ease, even though I have lpg pipe work.........
Post #349425 25th Sep 2015 10:05pm
Strider
so I understand.
greg. Bow down
Hi,
you are 100% correct :-http://wd40.com/cool-stuff/history.
I can also remember when RS was not 6+ volumes of industrial products for sale but 1 thin A4 booklet and was called Radio Spares. Opps this sounds like a decent into historical trivia Whistle .
Peter
Post #349433 25th Sep 2015 10:23pm
ebajema
SMUTT, I'm glad you got the b8stard out. I know how it feels having driven many old crates for decades. Also glad you got a good tip from JBA. WD40 is OK for what it was designed for and I do use it quite a lot as well but when it comes to this sort of stuff, I have a few penetrating oils on the shelves. Unfortunately the best (my dad found it and gave it to me years ago) is Reductor. No idea where to get it from, luckily I do have a few other penetrating oils.
The thing indeed is time, when the bolt or in this case that spark plug is so corroded into place, it takes a LONG time for the penetrating oil to work its way in and I'm glad that you didn't do the blunt thing (that I'm sometimes guilty of) and went all force and no finesse. Well done Smile. MY 2010 5.0 SC Galway green and sand interior!!
Post #349478 26th Sep 2015 10:55am
SMUTT
Thanks for everyones support - I have now changed all the plugs - No.7 also took several hours to get out but not as bad a state as No.6
Both plugs 6 & 7 appear (I suspect) greased before inserted. This has probably melted and worked its way down to the spark plug protruding into the cylinder, at which point it became baked hard when engine firing. It therefore acted like a nut inside the cylinder to prevent the plug coming out.
They were also marked BMW / Bosch FGR7DQP which could mean they were fitted in the factory - perhaps by a disgruntled employee who thought he would brighten his day in 13 years time at my expense.
Engine now runs beautifully - so happy - Very Happy Howard
Post #349493 26th Sep 2015 1:42pm
ebajema
Thumbs Up Thumbs Up Thumbs Up MY 2010 5.0 SC Galway green and sand interior!!
Post #349496 26th Sep 2015 2:06pm
