![]() | Home > Technical (L322) > L322 03 TD6 |
sounds like the fbh running... ... - .- -.
| bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109
I don't think so Stan its from that plastic box behind the battery some sort of ECU...I don't think mine has a FBH fitted webasto thing yes? If so then not fitted. |
so it doesnt power down at all?......i'd go back to the indy and let them sort it.. ... - .- -.
| gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077
Afaik all td6s came with fbh as standard, unless someone has removed it. |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
Yes, all td6 have the FBH from factory. 2011 Range Rover Vogue SE 4.4 TDV8
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
He will have a FBH but in this instance I think the OP is referring to the cooling fan for the ECU's behind the battery. 2008 MY Supercharged
| Vikash Member Since: 22 Apr 2013 Location: Milton Keynes Posts: 29
My 2003 TD6 hasn't been reliable for any Christmas |
