Home > General > This Forum is Great!
stoutgoose
United Kingdom 2012 Range Rover Westminster 4.4 V8 Zermatt Silver
The forum has been extremely useful in diagnosing many of the problems I have experienced, and has so far resulted in my being able to fix;
Smoke under heavy acceleration which was diagnosed as a technical bulletin modification and fixed under warranty.
Hesitation when cruising, diagnosed as an injector issue with a technical bulletin fix and carried out under warranty.
Boot window seals rotten and replaced under warranty.
Suspension air pump replaced with later upgraded type after fault warning, again under warranty.
Wheel arch rust spotting and fixed using parts and methods described on the forum.
Diagnosing FBH noise and confirming all was normal.
Replacing corroded wheel centre caps under warranty.
Deciding which tyres to use.
Plus many other smaller questions answered.
The warranty work alone has saved me several thousand pounds. Thank you fullfatrr.com!
Post #349377 25th Sep 2015 1:39pm
ajac8
+1. invaluable source of advice and info. Long may it and all the helpful folk here remain!! Thumbs Up Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #349381 25th Sep 2015 1:51pm
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
plus 1 for me too
Post #349382 25th Sep 2015 1:54pm
pld118
I think it's rubbish Laughing Wink
Post #349449 26th Sep 2015 7:12am
Laughing ... - .- -.
Post #349452 26th Sep 2015 8:13am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
This forum is great - but it does keep growing my list of preventative maintenance.
Things which I would never have known about include
1. PCV valve and pipework (done all 4 pipes)
2. Regular change of gearbox oil (LR sealed for life Rolling with laughter )
3. Bagpipe Andy's piston ring kit
4. Repair to LCD dashboard
5. Replace rear wiper
6. RSW AllComms
7. Rear wheel arch rust prevention
8. Merc Sprinter Bottle Jack (to replace LR supplied suicide jack Rolling with laughter )
9. Possible sudden failure of Air Struts
10. Wiper Relay YWB000060 failure
11. Likelihood of water pump failure
12. Reduced temp engine thermostat (80deg - thanks @Haylands)
13. Rear Manifold Hose adapter to Heater failure (the stubby one!)
SO thank you Forum Bow down Bow down Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #349461 26th Sep 2015 9:00am
