![]() | Home > Maintenance & Mods (L322) > Dash dimmer switch does nothing? |
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
As the title suggests, any ideas please (eg fuse)?
| MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471
What model? My 2011 AB with the TFT screen appeared to do nothing when you move the dimmer but in the dark it does actually dim it ever so slightly. "On first name terms with my local Dealer......now."
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2721
Sounds like it doesn't do much, mines the same ! |
Sold for 10 bob! As it's such a generous offer Alan, I'll ensure it comes with mats, flaps and a tank of fuel |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837
Since you're being so kind Ryan, you can have mine to keep you on the road |
As long as your dashboard dimmer switch works? |
But of course |
All noted Mr T and Mr P, thanks. It's a 2012MY. |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Yep, noticed the same. And as above its appears to have a light sensor which only dimmed it when it's dark. |
Damn, I was so hopeful too |
| wokkadriver Member Since: 10 Sep 2012 Location: Hampshire Posts: 31
This might be a reach but I had a Jag XKR a few years ago that needed to have the headlights in manual rather than auto and the steering column adjuster (I know, random or what…) set to manual too. Then the dash brightness dimmer worked. |
