![]() | Home > Technical (L322) > Handbrake stuck on |
Is the hand brake actually stuck on or is it just an erroneous message ?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16400 ![]() ![]() ![]() |
But for gods sake... ONLY use that as a last resort!!!
What happens to the brake when you pull that ?? And what is needed to "correct" the issue after pulling it ??? MY 2010 5.0 SC Galway green and sand interior!!
If all is well then nothing bad will happen Eugene... The H Brake should reset with 2 or 3 cycles... Its when it seizes your issues start! They are pretty good at self distructing too as the “Stop” is removed when you pull the emergency release... I have to add, all quite rare! BUT we all know how sods law will come along and deal you a blow, when your away and the wife has the car |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
Cheers guys I guess I'll tell her she's banned from my car lol I will also tell her to leave it until I get home L322 2008 vogue
Got back from work early ,so I had a look and when you go to start it comes up with handbrake fault and won't start I thought I would do the simple things first and have a look at fuses but the glovebox wouldn't open ? So starts taking apart the dash to try and fix that problem and found it nearly impossible to get open s had the obligatory brew then thought about it and thought it could be a low voltage problem for the glove box so chucked a charger on and it reads 60% charge so left it on charge and thumped the glove box and it opened ? Now just waiting for the battery to charge fully anyone got any more suggestions L322 2008 vogue
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8769 ![]() ![]() ![]() |
sounds like battery problems then......
Well a new battery charger revealed it only had 300amps and it stayed at 60% for three hours so being as it was the original battery I bought a new one for halfrauds with a lifetime warranty for £159 put it on and jumped to life straight away L322 2008 vogue
