![]() | Home > Technical (L322) > Suspension Fault |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801
i'd be tempted to disconnect the battery , do the left to right steering lock and see where that gets you.. ... - .- -.
| kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492
Thanks Stan I did the left right lock but didn't think about disconnecting the battery. Would that clear random codes? |
it wont get rid of any faults codes but i suspect the battery might have been disconnected when they did the hoses but the steering parameters were not set..
Thanks will get onto that in the morning worth a go to save a journey back to the dealers! Did I also read that a faulty ABS sensor gives the same message or would that come on when driving?? |
that could be the cause and they could have damaged it whilst doing the hoses.... ... - .- -.
Battery pull didn't fix it unfortunately so it was back to the dealer!! 10 minutes later after a code read they realised they hadn't plugged the height sensor it properly so that sorted it. Good news that it wasn't a big bill! |
thats a relief then |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Poor show that a main dealer can miss something as important, especially after doing a 'health check'...WTF |
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027
Er ... re-read your statement XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
It is pretty shocking and when I told them it must have been something they had done they didn't seem to be too believing!! What's worse is when the guy who did the health check flagged the warning to the service manager he apparently just said to leave it it's fine as it goes off again!! Gave me a nice cup of coffee though!! |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8746
What I can't understand is why they unplugged the height sensor when doing brake pipes, it's nowhere near and not connected to anything they would have to remove to do the job... |
Who knows unless it was a bit loose already and putting it on the ramp just disconnected it or they knocked it when doing the health check! |
I've read, re-read and re-re-read and still don't see what's wrong with it |
I've read it a few times and nor do I...
