![]() | Home > Technical (L322) > Can the convenience close be done with the Fob? |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
As the title says or is it only done with key in door? Thanks. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35817 ![]() ![]() |
if you mean windows up/down then yes it can be activated in the ccf with an iidtool.. ... - .- -.
It is easy to find out whether it is switched on. Open the windows, take the key out, get out and press and hold the lock button for some 2 seconds. It worked on my NAS 4.2 SC. I used the lazy or convenience unlock a lot to get rid of the hot air after it had been sitting in the sun. Hardly used the convenience closing but it did work.
Thanks folks, I thought there was a setting that I turned on through my iidtool. I will recheck it. Maybe I didn't save the setting. At this time its not working. The RAVE only mentioned the key in door method that I could find. Also my driver's door lock is not work too and wasn't sure if that was causing a problem. It all goes down fine.
