Home > Off Topic > Where can I buy this?
Andy
I'm looking for this upvc trim to fit to our upcoming decking all of which is the same as in the photo below.
The suppliers of the deck want £950.
It measure 3"x 1" and I presume it comes in strips.
 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #352562 16th Oct 2015 1:59pm
Looks like wood......
Try a building plastics supplier. In the midlands we have MBP (midland building plastics) don't know where you are but if you google building plastics near you then they should have something. they have different mouldings etc mostly used in facia and soffit work. There is nothing that can't be fixed with a hammer😜😜
Post #352584 16th Oct 2015 4:24pm
idrawcad
United Kingdom 2003 Range Rover HSE 4.4 V8 Alveston Red
Spaceage Plastics in Poole? My Motto: If you are going to have one, have a BIG one!
Post #352593 16th Oct 2015 4:57pm
Andy
Thanks.
It's upvc as I said, and the deck suppliers call it "ranch" trim. All of the decks on our site have to be from the same supplier for uniformity. I've looked closely at the plastic on my neighbours deck and it's literally two uprights and three to four horizontals stuck across them, then the whole thing bolts into the metal deck legs. I can't see how they're stuck together so I assume it's a hot glue gun or something.
My mate who helped me dig out the base is a self-employed builder and he said it would be easy to replicate and probably a lot cheaper. Another neighbour used real wood on his.
I don't have to buy the upvc trim and I don't have to buy from the deck suppliers either, so I would like to source it myself to keep costs down. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #352594 16th Oct 2015 5:11pm
mick-ne
England 2004 Range Rover Vogue 4.4 V8 Java Black
Here you go £24.95 you want the golden oak
http://www.deckbrokers.co.uk/index.php?rou...duct_id=92
Post #352772 17th Oct 2015 8:20pm
johnboyairey
Just stop at a window fitters truck and ask them, there are many suppliers, hidden on industrial sites. They have big charts with profiles, and most are in stock etc. You can find the typical stainless white headed pins (nails) to use on them, some have hidden tongue groove fixing points etc. Use a plumb line to keep heads in lines etc. It's very cheap, and it's very long. 3m or 5m lengths. If you have roof bars, borrow a very long plank of wood to strap the UPVC to as it flops all over the place. Just mention facia soffits and you are talking the right language.
Post #352775 17th Oct 2015 8:34pm
Andy
This is it close up:
Post #352884 18th Oct 2015 2:26pm
johnboyairey
I thought you meant the light green stuff. However, at the same suppliers, as mentioned above, in different colours, and probably same colour too. they will probably have best range to match. It will probably be the sort of solid stuff,
Post #352981 18th Oct 2015 11:45pm
