![]() | Home > Technical (L322) > New battery fitted - various issues! |
CY Member Since: 27 Mar 2007 Location: Scotland Posts: 146 ![]() ![]() |
Thanks for the suggestions.
Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 83 ![]() ![]() |
Geis a shout if ye decide tae sell it |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
When you disconnected the Ctek did you check the battery voltage.
Good call and probably the cause . Would have thought they had been checked already but easily overlooked .
Tom Paine Member Since: 11 May 2015 Location: Townsville Posts: 47 ![]() ![]() ![]() |
I suffered from all of this for a couple of weeks with my newly bought 2003 Diesel. My electrician and I finally traced it to the cooling fan. |
I managed to get the car started again by taking off the battery leads and cleaning them (with a can of coke and a toothbrush!). I gave it a full charge overnight but after 2 days it's lost about 60% of its charge, so there is still something draining it slowly (although at least it's not switching on!).
As your FFRR is of the bmw era , the heater fan coming on next time you start is probably normal .
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8765 ![]() ![]() ![]() |
I hope you used diet coke, our cars are fat enough..... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
I'd be inclined to go back and clean the battery posts and cable connections with emery paper, coke might work on coins but it's not much use on lead battery connections.
Think the FSR may be goosed... Having got the car started this morning, I just drove 200 miles to Durham and the blower would not change settings regardless of what I dialled into the controls...
Sounds like the front FSR is faulty.
