![]() | Home > Technical (L322) > ride height 30 mm lower at the back |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 ![]() ![]() ![]() |
Ride height is approx. 30 mm lower at the back on level ground in normal and raised setting . Is there a re calibrate method without a tool or is it best I just get my indy to fit 2 new sensors as they are cheap and reset using his equipment .
30mm lower than "normal" for the rears, or lower than the "front" ?
thanks joe, I used your chart to measure mine. My rears are 30mm lower than my fronts , should only be 10mm , so 20mm out , it can be seen visually as well which is what made me get out the tape measure. I did measure then when I first got fatty and they were just 10mm lower at the back , which is spot on acc to your table
Certainly worth having a look to see what state they are in |
good advice thanks , I will have a poke today |
Took it down to Landranger services in stockport. They put it on their automate and confirmed everything was ok but need a calibration, booked back in as it can take an hour or so to complete.
welderman Member Since: 03 Oct 2015 Location: Lancashire Posts: 14 ![]() ![]() ![]() |
I used Landranger for my RRS, good service all round and very helpful when I decided to fix my own transfer box |
I have my rear end set 10mm up, otherwise it looks like the car is always falling backwards. As it is now, it seems to sit properly. .
they gave my air suspension a check over read the volts from the sensors ect and were happy it was just a calibration issue..its been 30 mm lower since I got it 10 months ago, whatever height I set it at its always the same amount out.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Or is it 30mm higher at the front? What i mean is you need to measure all 4 corners and work out where they are in relation to where they should be. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2743 ![]() ![]() |
Remove the 20A suspension system fuse to prevent (downwards) levelling whilst parked. You will then know whether the leak is one side bag or air-line or the valve block if both sides. |
as ive said, I checked the dimensions against Joes chart , definitely the back was out , its all spot on now |
