Home > Wheels & Tyres > Front Tyre Wear 2012 Westminster TDV8.
stoutgoose
United Kingdom 2012 Range Rover Westminster 4.4 V8 Zermatt Silver
Vredstein Wintrac Extreme, 255/50/20.
Tyres have covered 10,000 miles since fitting. All of the tyres have worn evenly and still have in excess of 7mm tread depth, however the front outside edges are showing signs of wear and have probably lost another 3mm more than the rest of the treads.
I realise that edge wear is always going to be greater due to scrub and turn in, however before I blow £80 plus on a four-wheel alignment I wanted to get a general feel as to whether this is a normal feature of a 2.7 tonne car?!
How does yours wear?
Post #354640 29th Oct 2015 10:10pm
My Vreds always wore badly on the front outer edges - about an inch into the tread.
I ran Michelins in the summer and they were fine.
2 sets of Vreds did the exact same thing, but it was only the outer edge, so just put them on the back for the next winter.
I've just bought some Winter Contis for the L405 so will see if they fare any better
Post #354642 29th Oct 2015 10:18pm
stoutgoose
Thanks, that's exactly what mine are doing.
I'll swap them front to rear.
Post #354645 29th Oct 2015 10:26pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Re: Front Tyre Wear 2012 Westminster TDV8.
I think you hit the nail on the head, assuming your front suspension geometry is OK.
You should also consider that these heavy machines can corner quite well, but the higher the speed, the greater the tyre scrub, so driving style could/will also contribute. Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #354646 29th Oct 2015 10:35pm
stoutgoose
Er, yes. I figured that my driving style was a potential contributor.
I try to avoid braking unless necessary!
Post #354647 29th Oct 2015 10:42pm
3528cc
High speed cornering on bends would be the root cause................... Regards
Royston
1999 Rover BRM
Post #354648 29th Oct 2015 10:50pm
Mikey
I have 20" Scorpion winters, and they are wearing exactly the same...
Post #354650 29th Oct 2015 11:07pm
stoutgoose
Conclusion; Eighty quid saved but need to slow down on corners!
Thanks all!
Post #354654 29th Oct 2015 11:23pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Braking on the turn will do it, I know this after wearing out some expensive BF Goodrich tyres that way.
I now loose my speed before a turn and drive through, lesson learned Embarassed
Post #354658 29th Oct 2015 11:35pm
stoutgoose
That's one thing I don't do. Destabilising a heavy car mid-corner is a scary thing.
I prefer to lift off the gas early and coast up, then dab the brake to adjust speed prior to turning in, but keeping the speed as high as posssible.
Post #354659 29th Oct 2015 11:40pm
My driving style could also be called 'enthusiastic' Whistle but I also try not to change speed through bends.
Must be something to do with tyres / sidewalls though as the Diamaris were fine Thumbs Up
20" Contis were also well known for scrub, but the 22's seem OK
Post #354682 30th Oct 2015 9:33am
stoutgoose
I'm going to try 255/55/20 tyres next time.
From what I've read on here, there doesn't seem to be any significant negative issue with them.
Post #354694 30th Oct 2015 11:04am
Swap them side to side before moving them to the rear.
Does mean demounting and remounting the tyres but will get the wear on both sides then and then stick the pressure in them for a laden vehicle and they will wear in the middle more to even it all out once on the rear Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #354710 30th Oct 2015 2:34pm
most FF tyres are asymmetrical Will, ie they will have the word 'outside ' written on the side wall... ... - .- -.
Post #354714 30th Oct 2015 3:04pm
Stanley have you mislaid your specs today Wink
Post #354720 30th Oct 2015 3:36pm
