![]() | Home > Technical (L322) > Front prop shaft is fouling the cross member. |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Front prop shaft is fouling the cross member, it is a shiny band right above the bar in line with the bell housing/ torque converter housing. There was a good gap when I looked. Anyone got any ideas why there may be contact? |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
If it's fouling the cross member then you have serious problems with the engine or gearbox mounts!
A photo or two sorry best I could do not as agile as I used to be
A picture is worth a thousand words, that has helped a lot.
There is no noise or jerking selecting D or R, in fact it is silky smooth compared to the excellent Toyota box I used to have and I thought that was good. 85K miles and still the original guess the drive shaft joint is ok.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8762 ![]() ![]() ![]() |
Your gearbox sump looks damp as well, if it is oil I'd get a gearbox service done asap... |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1854 ![]() ![]() |
Unnecessary quote removed
Spoke to Land Rover not turned down yet, although not looking like a free of charge upgrade as they call it.
Is it giving you a problem?
