Home > Technical (L322) > Which Mass Air Flow sensor?
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Dear All,
Can anyone confirm which MAF I need for my pre-face lift MOST 54 plate 4.4 M62 (2005MY)? Having logged onto various sites they recommend different parts to the Bosch 0280217814 sensor fitted and other sites say that the Bosch is the one to fit. Does the MOST system use a different MAF or is the Bosch the right one?
Confused!!
Regards and TIA for any help.
John
Post #355618 6th Nov 2015 10:05pm
Dolphinboy
Go for OEM every time. Bosch is the one to have. I have just changed mine and others just don't ,are the grade. Not much more expensive either.
Post #355628 6th Nov 2015 11:53pm
Mikey
The 4.4 petrol only lists one MAF, with part number MHK000230
https://www.lrdirect.com/MHK000230-Sensor-...wwodmCgJEQ
On OEM Bosch sensor is 3x the price of the cheap Britpart one, but you will only buy 1 Bosch sensor Thumbs Up
Post #355640 7th Nov 2015 9:04am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
I was going to suggest Bosch as fitted to mine. However my ignorance of what MOST meant I did not have a clue Embarassed Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #355641 7th Nov 2015 9:09am
tb10
Cheers Guys - appreciate the replies and confirmation.
Sorry Smutt - my car is one of the 'difficult' cars which has the old front end but with the 2005 fibre optic canbus etc so the reference to the MOST system was a question if the MAF needed a different sensor due to resistor issues rather like the upgrade to the 2012 rear lights needs a resistor pack to solve the flashing LED issue.
Regards
John
Post #355642 7th Nov 2015 9:12am
fisha
Buy direct from the dealer . . . Been there before, tried mail order multiple times and they didn't work correctly. Bought from the dealer, and it worked first time. It's one of the few things I'll pay the extra for to guarantee genuine. V8 or else ...
Post #355649 7th Nov 2015 9:53am
tb10
Thanks Fisha
regards
John
Post #355653 7th Nov 2015 10:02am
Mikey
OEM is exactly the same part, but without paying Land Rover tax Thumbs Up
In this instance, an OEM sensor is £101.17
To buy from a main dealer, it is £145.78, for exactly the same part
Why would you pay more? Thumbs Up
Even genuine parts have been known to not work straight out the box
Post #355654 7th Nov 2015 10:03am
SMUTT
^^-- Agree with Mikey and Fisha - I learnt the hard (expensive) way that OEM part for the MAF is well worth the money.
@TB10 - thanks for explaining MOST Smile Howard
Post #355656 7th Nov 2015 10:17am
fisha
Like I say, I've been down the route of trying cheapest ( didn't work ), mid-range supposed to be decent (didn't work) and finally genuine ( did work first time ).
The wasted cost of the cheapest + mid range together was way more than difference in cost between an OEM part and LR dealer ... so rather than have doubt, when it comes to the MAF, its worth paying the LR price. Yes it more, but at £40 difference, its worth it imho as the MAF readings are very very sensitive, and need to be spot on.
In other areas of the car, then I'll look for the balance of cheaper parts, but not the fuelling system. V8 or else ...
Post #355669 7th Nov 2015 11:23am
Mikey
I'll agree with your cheapest and mid-range options, but the OEM part is EXACTLY the same part as you would get in a Land Rover box...
Post #355699 7th Nov 2015 1:26pm
chex
Kenya
If you buy online make sure the vendor tells you it's OEM before shipping.
With sites like britishparts its a crap shoot what you get. 2004 L322 V8
Post #355805 8th Nov 2015 7:47am
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
Buy from Dan every time
Idea
Post #355815 8th Nov 2015 9:51am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Try www.maf-shop.com
They only sell genuine Bosch or Seimens MAF's.
Exactly the same part as LR would supply except in a Bosch box.
I've used them before and saved over £250 compared to manufacturers prices (that was a dancing donkey though).
The Bosch 0280217814 you list comes in at £79.13 + shipping.
Post #355866 8th Nov 2015 4:23pm
tb10
Thanks to everyone for replying. I'll feedback the results hopefully noting an improvement in economy!!
Regards
John
Post #355870 8th Nov 2015 4:43pm
