![]() | Home > Maintenance & Mods (L322) > L322 service quote |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
You only need to have the servicing carried out by a "VAT registered garage", it doesn't have to be a franchised Land-Rover dealer or even a Land-Rover specialist, just VAT registered.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3881 ![]() ![]() ![]() |
Not sure where they are, but Rcv.co.uk quote £511. Fully Land Rover trained technicians.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668 ![]() ![]() |
I can recommend these people if you can be bothered to travel http://www.woburn4x4.co.uk/servicing.html
dand Member Since: 03 Sep 2014 Location: Wokingham Posts: 50 ![]() ![]() ![]() |
My Inspection 1 back in July was ~£460 from a well respected specialist. For the price you've been quoted I hope they'd wash it too. |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
Would a 2011 not be under some kind of extended warranty i.e. insurance backed. In that case I think you'll need to check the policy terms as these warranties are not covered by Block Exemption. BMW AUC warranty dictated that the car had to be serviced at a main dealer. Things may have changed but best to check. RCV are in Staplehurst in the wilds of Kent. 2017 5.0 Autobiography Supercharged 2005 Merc SL350 2005 Disco HSE 2.7 oil burner |
http://www.usedvehicles.landrover.co.uk/pd...rranty.pdf
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3345 ![]() ![]() ![]() |
Try shopping around. Prices vary wildly.
anchorman Member Since: 09 Nov 2015 Location: London Posts: 12 ![]() ![]() ![]() |
Thanks all. I have just got home and have read Condition 12 in my Approved Warranty manual, as noted by pld118. Good news that I can go with a specialist should I so choose. It's amazing that there is such variation in servicing pricing. I'll definitely be shopping around! |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 188 ![]() ![]() ![]() |
Most of the main dealers offer a service package.
Wow... Do people still fall for that old 4yr package deal |
Good news indeed. 2017 5.0 Autobiography Supercharged 2005 Merc SL350 2005 Disco HSE 2.7 oil burner |
I'm not in any way standing up for the dealers, however I'd be interested in why you make this statement? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8785 ![]() ![]() ![]() |
Another tip Is to source the correct oils yourself, the dealers charge an arm and a leg for the fluids, buying the oil separate saves quite a few pennies |
Very true, but you don't even have to use the main dealer at all. Just a VAT registered garage. Engine oil is the worst rip off from main dealers though, when you consider most of them will buy it in bulk drums, even more cheaply than you can source it in bottles. |
