Home > Technical (L322) > Repaired - Can't find this eas problem using search:
Lenb
England 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
So I've just sorted the 'failing to run' problem (replaced fuel pump), and now I have an eas problem:
Whilst driving today I suddenly had a 'rumble' sound that came from offside front and sounded like loosing traction. It would happen on acceleration (hard) and then again on braking (hard). I had to drive home about 12 miles and ended up with 'inactive suspension'. Checking faults I had both ABS - 0x8a air suspension system CAN error and EAS 0x64 Articulation Validty Fault. Clearing these they would return once driven again.
I then noticed that the front suspension air bag was completely soft whilst the rest were hard (but the corner was not particularly low). Raising it to off-road height it stays inflated. Driving it again at normal height you seem to get a catastrophic deflation for it to only pump up again and remain when parked.
I think I've worked it out but would like opinions before I spend £200 on a new strut:
The bag leaks when a forward or reverse action exposes hole/split. The 'rumble' is tyre slip because of no pressure in bag allowing it to 'bounce' when driven hard (ish). The 2 errors are because of this.
Am I on the right tracks? Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Previous: 2000 P38 DHSE - 1995 P38 DT Man - 1990 3.9 SE Classic, 1980 3.5 Classic 2dr
Post #356721 13th Nov 2015 7:05pm
Sounds about right, I'd confirm the split before replacing, and as the shock is integral with the strut you should change them in pairs... Delphi are OEM, Dunlops apparently don't last as long.... Pete
Post #356722 13th Nov 2015 7:15pm
Lenb
It's been standing now for a couple of hours and you can push the bag in with your thumb about half inch (the others are solid). I've tried the soapy water but can't see any bubbles. Is there anywhere else where air can leak out affecting just one air bag?
Len Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Post #356728 13th Nov 2015 7:32pm
The struts are not connected to each other usually so it will be somewhere on the bag or in the pipe from the front valve which is at the rear of the drivers wheel arch. The hole could be in the fold of the bag and leaking very slowly so you won't hear it and bubbles could take some time to show themselves, start the engine, take it up to off road height and try the soapy water. Pete
Post #356775 13th Nov 2015 9:58pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
As Haylands says.
The split in the airbag is probably tucked out of sight in the 'roll' so it's pressed against the strut and partially sealed at normal height. As soon as there's any movement in the suspension then it leaks (and gives you the issues you describe). Try leaving it in off road height and squirting a lot of soap and water up under the roll of the bag at the bottom. You could also try jacking that corner up (on the chassis) so the strut droops, I could hear mine leaking before I found it with soap and water.
The only other place it could leak on that one corner would be the pipework back to the cross link valve, worth checking but the air bag is the most likely place for leaks.
One of the cheapest places for OEM replacement struts is Island4x4.
Post #356779 13th Nov 2015 10:15pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
My front O/S bag has a leak, initiallly hard to find, but after a few days got worse. If I raise the car to off-road height, I can hear air hissing out of the centre of the strut. have just bought 2 new Delphi units from Dan @ Duckworths, Island are quoting £249.50 + vat, Dan did them for £225 + vat Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #356792 14th Nov 2015 12:07am
Lenb
Repaired!!!
Bought two struts from Paddocks, £258 each (Delphis). Turned out near side had been done about 2 years ago (before I bought it) but was a Dunlop (will sell this on the bay of e). Offside was original, so now waiting for the rears to go Smile
Post #357475 17th Nov 2015 9:17pm
Rears last much longer than fronts, mine is still on the originals... (jinxed them now though Rolling Eyes )
Glad it's sorted
Thumbs Up Pete
Post #357479 17th Nov 2015 9:24pm
Lenb
That's nice to know, could do with a bit of a rest from repairs - especially as it's now cold and wet Very Happy
Post #357480 17th Nov 2015 9:31pm
"cold and wet".... aaarrr that'll be new alternator and battery then..... Whistle Whistle Pete
Post #357519 18th Nov 2015 12:30am
