![]() | Home > Technical (L322) > Will an L322 fit in my garage? |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 314 ![]() ![]() ![]() |
Who cares buy it |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3204 ![]() ![]() ![]() |
Have a look here: http://www.fullfatrr.com/forum/topic29359....ss+heighth John
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
My 2003 will drop by 40mm to "access height" hope that helps |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 ![]() ![]() ![]() |
Unnecessary quote removed
Stephen.Gazard Member Since: 10 Apr 2012 Location: Bristol Posts: 184 ![]() ![]() |
It's worth noting the shark aerial on the roof is different heights also.
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
It will not go in mine so I have just pulled it down and making it twice the size and raising the height also ! |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
I'd say it depends what the garage is made out of |
362bkr Member Since: 15 Oct 2014 Location: Devon Posts: 679 ![]() ![]() ![]() |
Well if there is an opportunity to own a Range Rover then surely it's worth moving house for !? |
dand Member Since: 03 Sep 2014 Location: Wokingham Posts: 50 ![]() ![]() ![]() |
I've got a standard size garage with an up and over door and there's no way the RR will fit in even on the lowest setting. |
exalin Member Since: 14 Jan 2015 Location: Cheshire Posts: 69 ![]() ![]() ![]() |
From the owner's handbook on TOPIx for MY10 onwards, which is what you're looking at clarence:
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Tried mine in my garage just the once, not long after I got it. Height wise, just squeezed under the open door. My God but it's big! Previous cars:
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
The biggest problem with most garages is if you can actually get the car doors open once you've driven in there. Most of them seem to have been designed for Austin 7's. (bearing in mind i've not seen your garage), i'd say make sure you consider the width as well as the height. |
