Home > Technical (L322) > Will an L322 fit in my garage?
clarencepier
I am seriously considering buying an L322, most likely a 2009 5.0L petrol. I'm trying to establish if such a vehicle will fit in my garage, height being the limiting factor. The published specifications on Parkers website quote the height as 1865mm but doesn't state what suspension setting that is for.
At that height, it will be just a tad too high to fit. So is this dimension likely to be for the vehicle's lowest setting?
Post #357970 21st Nov 2015 6:30pm
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Who cares buy it Very Happy
Most quoted figures are for normal driving not the low access mode Many thanks
Paul
Post #357974 21st Nov 2015 6:40pm
Weegie
Have a look here: http://www.fullfatrr.com/forum/topic29359....ss+heighth John
GAP iiD BT-Sold
Post #357975 21st Nov 2015 6:41pm
Clivefog
My 2003 will drop by 40mm to "access height" hope that helps
Post #357976 21st Nov 2015 6:52pm
johnboyairey
Re: Will an L322 fit in my garage?
Unnecessary quote removed
i am guessing that the limiting factor of garage height, is the up and over door.
remembering to lower the car everytime you drive it in and out is going go wrong, once, and that too many... you could consider changing that up and over door to a modern electric roller shutter. these are often white, but can be other colours too. it could also mean that its remote control, and more secure, -and you wont whack your head on the lock, of the old type.
if its a pair of open out doors. you might be able to trim the crossbeam, and extend the door heights.
i sometimes drive into low shopping carparks and it rattles the dangling warnings poles, as i have my roof bars on a lot. -i drop it down, and drive real slow, to keep it down. i have to remember to drive slowly out, so i dont catch any possible lights or even worse, wedge it on an up ramp! Evil or Very Mad
where we take our motorcaravan for MOT, i have to hold away a dangling light with some old wire, so it goes under, and again, im fearfull the spotty kid with drive it out, and knock all the skylights to pieces.
Post #357979 21st Nov 2015 7:03pm
Stephen.Gazard
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
It's worth noting the shark aerial on the roof is different heights also.
Early - none
Mid - tall
Late - lower
I have 2007 model and swapped the shark fin to a later model to ensure i could get in previous garage ....
However would agree with previous post on replacing door with roller shutter to get extra space. Stephen Gazard
Range Rover L405 LWB SVA Overfinch / Bespoke
Maserati GT 2017
Maserati Levante Trofeo
Mercedes SL63 AMG
Mercedes S500L
Post #357994 21st Nov 2015 9:26pm
Rangeyman
It will not go in mine so I have just pulled it down and making it twice the size and raising the height also !
Post #358015 22nd Nov 2015 12:10am
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
I'd say it depends what the garage is made out of Laughing
Post #358017 22nd Nov 2015 12:20am
362bkr
Well if there is an opportunity to own a Range Rover then surely it's worth moving house for !? Very Happy
Post #358054 22nd Nov 2015 10:55am
dand
United Kingdom 2008 Range Rover Vogue SE TDV8 Barolo Black
I've got a standard size garage with an up and over door and there's no way the RR will fit in even on the lowest setting.
Post #358150 22nd Nov 2015 9:28pm
exalin
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
From the owner's handbook on TOPIx for MY10 onwards, which is what you're looking at clarence:
I've had mine in car parks with 1.8m max height signs although it was very tight.
Post #358177 23rd Nov 2015 12:26am
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Tried mine in my garage just the once, not long after I got it. Height wise, just squeezed under the open door. My God but it's big! Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #358190 23rd Nov 2015 8:06am
Zirconblue
The biggest problem with most garages is if you can actually get the car doors open once you've driven in there. Most of them seem to have been designed for Austin 7's. (bearing in mind i've not seen your garage), i'd say make sure you consider the width as well as the height.
Post #358454 24th Nov 2015 10:55am
