Home > Technical (L322) > SC Radiator Drain Screw
dhallworth
I went to drain the coolant on the SC today to do a flush on it. I noticed that the drain screw on the bottom on the radiator has had the thumb screw snapped off it.
It appears to have sheered flush with the radiator, if I remove it, does anyone know if you can buy just a bleed screw?
Failing that, I'm just going to take the bottom hose off it and drain it that way I think unless anyone has any other suggestions.
Thanks
Post #357997 21st Nov 2015 10:17pm
fisha
I pull the bottom hose. It's quicker ! V8 or else ...
Post #358002 21st Nov 2015 11:08pm
