![]() | Home > Maintenance & Mods (L322) > Lower tailgate wont stay closed |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35808 ![]() ![]() |
if the latches arnt latching then undo the screws and move them... ... - .- -.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
A good squirt of WD40 and work them manually a few times |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
when you press the button to open the lower can you hear the solenoid? kinda makes a 2 stage noise.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
What he said. ![]() 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
It's possible the latches aren't latching over the locking pins correctly.
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 ![]() ![]() ![]() |
thanks for all the helpful pointers above.
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
Same happened to mine,went a couple of months and just did not work then just started working again ??that was quite a while ago and did it again the other week but worked after a sharp slam ??,am sure there is a reason but am not convinced on the answers above . |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
There is a small thin plastic slider (looks and feels a little like an emergency handle that lifts up) so, lower the tailgate and pull both plastic sliders upwards towards the top plastic bar that has the tailgate release button inside. There is an internal spring that should make them pop up when the latches release, if they are down then something has failed/stuck... Lifting them manually allows the latch to re-engage... Then close the tailgate and see if that allows it to close correctly? If it does? Then you will need to pull them up every time you open the lower tailgate, to enable it to close again... Not a permanent fix, but at least allows you to use the car whilst you sort out the issue/lube/free off etc etc etc |
AlanS Member Since: 23 May 2019 Location: North Lincolnshire Posts: 18 ![]() ![]() ![]() |
My tailgate wouldn't lock all of a sudden. No sign of an issue until it plainly just stopped locking. Managed to keep it engaged with the top gate to get home. Removed the 2 black lock mechanisms, be careful when you remove the locks after you have taken out the 2 bolts. There's a small square plastic part that engages with the locking mechanism. I managed to remove the plastic part from its axle/fixing point. No Biggie, just had to remove the bolt that holds the tail gate support cable, remove the mechanism on the tail gate that's behind the metal frame of the gate (once the door card was removed) re engage the little spring, reassemble and job done. A good clean out of the locking mechanism with brake cleaner and then lithium grease when dry and it's all fine now. 2012 L322 4.4 TDV8
