Home > General > Hi again...anyone know this one?
silverbackmike
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Hi chaps,
Anyone know this one? I'm buying in the next couple of weeks and although miles away looks ok. Your thoughts and views appreciated...
Mike
Post #361567 10th Dec 2015 7:47pm
silverbackmike
It's up for just over 10k with lots of history etc
Post #361568 10th Dec 2015 7:48pm
archermav
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Seems cheap enough, but that interior has seen some wear. Steering wheel very worn, seat squab knackered and the drivers door pull looks like it's never been cleaned. New turbo's may help you feel more at ease I suppose? It's priced at 10,990, I like your man maths.
Post #361585 10th Dec 2015 10:29pm
Rangeyman
If you are coming from somerset to spend 11 grand on this pay extra for an 'AA inspection' or equivalent.I do not know this garage personally but will ask about as am sure some one
forum.landrovernet.com/showthread.../268222-Pennine-autos-bradford
17 Oct 2014 - 8 posts - ‎6 authors
Pennine autos bradford. Stay clear of these robers sold me a unworthy landrover With 12 months mot and tax only to find 6 months down the ...I know will but you could check this ...
Post #361592 10th Dec 2015 10:53pm
Rangeyman
eBay item number:
eBay Item No. 201480526802 A bit nearer home and private sale so you can knock a chunk off ...
Post #361597 10th Dec 2015 11:10pm
silverbackmike
Thanks for the replies and good spot rangeyman re the Winchester one! It's on my watch list now.
And yes, my other half never ceases to be amazed by my man maths and justification of said maths Thumbs Up
Post #361599 10th Dec 2015 11:17pm
Have a good look underneath
Check the MOT history of a vehicle
Registration number: E4KCB
Mileage readings are currently only available for MOTs done from 1 August 2011.
Vehicle makeLAND ROVER Vehicle modelRANGE ROVER Date first used4 December 2006 Fuel typeDiesel ColourBlack
MOT history of this vehicle
Test date4 February 2015 Expiry date22 February 2016 Test ResultPass Odometer reading120,806 miles MOT test number9669 1573 5072 Advisory notice item(s)
Nearside Front Brake pipe slightly corroded (3.6.B.2c)
Offside Front Brake pipe slightly corroded (3.6.B.2c)
Nearside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Offside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
both rear subframe bushes starting to split but no movement
Test date3 February 2014 Expiry date22 February 2015 Test ResultPass Odometer reading108,491 miles MOT test number3963 0463 4004 Advisory notice item(s)
Nearside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Offside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Nearside Rear Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Offside Rear Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Nearside Front Track rod end ball joint has slight play (2.2.B.1f)
Test date23 February 2013 Expiry date22 February 2014 Test ResultPass Odometer reading94,916 miles MOT test number5182 2405 3008 Advisory notice item(s)
Nearside Rear Lower Suspension arm has slight play in a pin/bush (2.4.G.2)
Offside Rear Lower Suspension arm has slight play in a pin/bush (2.4.G.2)
Nearside Rear Brake pipe slightly corroded (3.6.B.2c)
Offside Rear Brake pipe slightly corroded (3.6.B.2c)
Nearside inner rear tyre has a small tear on sidewall.
Child seat fitted not allowing full inspection of adult belt
Under-trays fitted obscuring some underside components
Items removed from driver's view prior to test
Test date22 February 2013 Test ResultFail Odometer reading94,910 miles MOT test number8981 1365 3088 Reason(s) for failure
Nearside Front Lower Suspension arm has excessive play in a ball joint (2.4.G.2)
Offside Front Lower Suspension arm has excessive play in a ball joint (2.4.G.2)
Test date3 February 2012 Expiry date2 February 2013 Test ResultPass Odometer reading85,253 miles MOT test number8290 0463 2008
Test date2 February 2012 Test ResultFail Odometer reading85,253 miles MOT test number6496 9303 2093 Reason(s) for failure
Nearside Rear Tyre has a cut in excess of the requirements deep enough to reach the ply or cords (4.1.D.1a)
Offside Headlamp aim too low (1.Cool
Parking brake: efficiency below requirements (3.7.C.1b)
Brake hydraulic reservoir fluid close to minimum level (3.6.G.1b)
Front Brake pad(s) wearing thin (3.5.1g)
o/s/r tyre side wall damage
n/s/f tyre side wall damage
all discs worn
Test date21 December 2010 Expiry date23 December 2011 Test ResultPass MOT test number4828 6555 0498
Test date24 December 2009 Expiry date23 December 2010 Test ResultPass MOT test number5424 0805 9342
Post #361602 10th Dec 2015 11:42pm
silverbackmike
Thank you very much for adding that list. Much appreciated....I may just dodge this one!!!
Post #361604 11th Dec 2015 12:10am
Shocked Is that MOT info publicly available ?
I think we need a link to that web site Whistle
Post #361630 11th Dec 2015 4:33am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
All on the Dot Gov website.
https://www.gov.uk/check-mot-history
It gets a bit wobbly when the car has/has had a private reg but it's better then nothing. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #361636 11th Dec 2015 7:23am
Post #361671 11th Dec 2015 11:30am
