Home > Technical (L322) > Air susp inactive
Stormin
2003 Range Rover HSE Td6 Epsom Green
Air susp inactive
My suspension has locked, with the light on in the height switch and the warning on the dash.
Just had the codes read and it said something like fluid reservoir and can bus.
We cleared the codes and the pump could be heard and the vehicle went up and down when requested.
However the warning reappeared after about a 5 min drive.
Having read similar posts on here I'm thinking height sensor.
Question being, how do I find out which one and how easy are they to change.
Thanks Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #361848 12th Dec 2015 3:59pm
Check you brake fluid!
If this is low it will lock out the suspension for safety reasons. .
Post #361851 12th Dec 2015 4:12pm
Stormin
Thanks joe 90 its not the brake fluid Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
Previous cars
1973 Mini 1000
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1996 BMW 730
2003 Honda CRV
Post #362062 13th Dec 2015 4:09pm
If it is a height sensor you should be getting an "articulation fault".
Worth checking it is not an airbag (hole covered up at normal ride height so no air lost) Put in off road height, and turn off engine. Listen for hissing, lift each wheelarch. Soapy water etc.
Whilst in offroad height, easier to check underneath (without getting under!) for broken height sensors. Rears more difficult easier to take the wheel off for a good look
Need to check the fault codes again. Did the garage/friend clear all as the air suspension fault get logged in several ECUs and can come back!
Ah, sure it wasn't an air reservoir fault? These can be "fun" to sort out - valve block / pressure relief valves? .
Post #362075 13th Dec 2015 5:03pm
