![]() | Home > Maintenance & Mods (L322) > Scary Moment |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8800 ![]() ![]() ![]() |
Very interesting.... what act and section covers that then????????? Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
The Road Vehicles (Construction and Use) Regulations 1986 or Highway code section 239 covers requirement for handbrake and use of 56 TDV8 Vogue SE
Strider, your “E” brake has two functions sir... 1, it acts as a parking brake below around 10mph & 2, above a certain speed it then acts as an emergency brake! Try driving at 30+mph and flick the switch up! BRACE YOURSELF! and make sure you have no one following you!! As it applies the EBA and tries to force you & the contents of your car through the windscreen! So, do NOT let toddlers (that like to fiddle with switches) sit in the front when traveling ![]() Its good practice occasionally to drive at walking pace and flick your parking brake on & off a few times as it cleans all the surfaces up and lowers the risk of it sticking on! Hope that helps ![]() |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
Strider, your “E” brake has two functions sir... 1, it acts as a parking brake below around 10mph & 2, above a certain speed it then acts as an emergency brake! Try driving at 30+mph and flick the switch up! BRACE YOURSELF! and make sure you have no one following you!! As it applies the EBA and tries to force you & the contents of your car through the windscreen! So, do NOT let toddlers (that like to fiddle with switches) sit in the front when traveling Shocked
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1424 ![]() ![]() ![]() |
I wonder whether the handbrake is actually the problem. My experience is the same as that of 47p2, in that if I put the car into the garage after washing (and particularly if wheel cleaner had been used) the pads can stick to the discs. I don't apply the handbrake when the car is in the garage as the floor is level, it is just in 'Park'. There is a bang when the pads release from the discs and as 47p2 says the best thing is to drive the car after washing to dry and clean the brakes and discs. Only Range Rovers since 1988 |
The bang will be the normal rear pads sticking to the disc surface as they pretty much hover over the disc... However i will say, the cheaper the pads, the more metal will be in them! And we all know what happens to bare metal with water on it! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Exactly which is one reason why manufacturers have to fit them. Haylands, You did ask what the point of them of was so I replied. |
Unnecessary quote removed
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
I don't know the exact bit of legislation, I'm not that sad ![]() I did hear something that JCB had to create a vastly complex steering setup for the Fastrac because it could do >40mph, and the tyres so big. The fact that this steering system is probably more unreliable than normal PAS is beside the point. Ed |
I said "what's the point" not "why do we have to have one"
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
its sometimes difficult to shift out of park if left in park on a hill, the handbrake comes in handy then... .. ... - .- -.
As i clearly said in my original post, i'm not judging just answering your question. I don't care whether you use yours or not, but the law clearly says you must. "What is the point of one" and "why do we have one" mean the same do they not? Both seem like plain English, and they both mean the same thing. Q. What's the point of a handbrake on an Auto? A. The point is the manufacturer is complying with the law by providing one, and giving you the opportunity to comply with the law when using the vehicle. Q. Why do we have a handbrake on an auto? A. Because the manufacturer has to fit one to comply with the law and it allows you the opportunity to comply with the law when using the vehicle. As I also said regarding it being a secondary brake, it's not going to do much but it's better than nothing. I would recommend re-reading my post as you obviously took offence to my non-aggressive and non-judgemental comment!
Well if i recall correctly (i can't be bothered to look), the highway code says words to the effect of "you MUST apply your handbrake when leaving your vehicle". So i'd say that still says you need one, although you're probably right about MVC&U also saying you have to have a secondary system too. |
Opppps Sorry Stan |
