Home > Technical (L322) > Help needed with boost noise from dash
paul_h_8
2002 Range Rover Vogue Td6 Bonatti Grey
Only started today but my TD6 seems to have developed a fault. When foot down on accelerator pedal and over 2k revs I'm getting a loud boost noise through the centre top of dash. Any advice
Noise sounds like what my Subaru impreza used to sound like but that was running silly power and had a boost gauge on dash.
Power seems the same and it doesn't seem to get any louder through the revs.
Thanks in advanced
Post #34428 30th Oct 2010 7:23pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Its not unknown on the BMW equiped motors for the inlet manifold to split though I've yet to hear of one on a FFRR. That said you would expect it to run like a bag of spanners.
Is it a Ptsssssstttttt noise or something else Question
Worth checking--- the EGR links to a large rubber pipe which in turn links to a large ali pipe which runs down the back of the radiator. On my TD6 this had a rubber hose chaffing on it which wore theough the alloy to the point the pipe became pourous. This Alli tube carriers the pressurised air from the turbo.. again may be worth a peep. I was stunned that the rubber wore through the ali and not vice versa. Hey ho! 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #34445 30th Oct 2010 9:53pm
paul_h_8
Thanks for above.
RR is running fine so hopefully not Manifold issue.
Noise is like a PTTSSSSSTTTTTTTTTT as you mentioned. only happens when foot on pedal and over 2k revs.
I'm not really sure where to start and think i'm best to book it into a RR Indy garage.
Can anyone reccomend any in North East? near middlesbrough
Thanks
Post #34545 1st Nov 2010 12:51pm
paul_h_8
Found these guys local http://www.northeastern4x4.co.uk/about.html
Has anybody used these guys?
Post #34547 1st Nov 2010 1:14pm
paul_h_8
Inlet manifold gaskets had worn causing the slight noise. just had call from garage only £22 for part. Said noise was only slight, but guess i'm very picky lol
Heads up for anybody else though
Post #36224 15th Nov 2010 4:43pm
good cheap result paul..... Thumbs Up ... - .- -.
Post #36229 15th Nov 2010 5:17pm
paul_h_8
2 hours labour aswell though Very Happy
Also getting gearbox oil flushed and rear passenger dooe lock changed. Still not a massive cost and had a full check ready for my first winter in the RR.
Post #36231 15th Nov 2010 5:21pm
M44K TS
Are you getting that done at NE4x4? 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #36244 15th Nov 2010 6:35pm
paul_h_8
Yeah you know them like?
Post #36270 15th Nov 2010 8:59pm
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
Did this rectify your noise? As I think I have this. Bushy
2003 RR Vogue Monté Carlo Blue
Post #202312 4th Aug 2013 5:22pm
