![]() | Home > General > Adaptive Cruise Switch Early 2010MY |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
You'll see on a pic of the rear that it's all there and should have a square plug covering the receiver .
You can just about see the square on these pics of our car .
Eric Cartman Member Since: 05 Nov 2014 Location: Dublin Posts: 108 ![]() ![]() ![]() |
Heres the steering wheel controls
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
Hi Eric
Also - the Tow Bar prep means it has the wiring already run to the boot area (rear right as you look at it)
Cheers for all the help, that certainly clarifies it hah, the 2010 model seems to have more controls than a space shuttle .
So once you have enabled the adaptive part (forward warning) and set the cruise, you use those two to alter the distance you follow the car in front by. Obviously the top one reduces the gap and the bottom one increases the gap.
Those are the buttons to adjust the adaptive following gap, i.e. the distance it holds between you and the car in front. They also adjust the alert gap for forward alert. Without those it won't have adaptive cruise. Enabling forward alert, even if it's actually there (which I doubt) won't give you adaptive cruise, it's just the alert that you're closing in on something and as I mentioned it also uses the same buttons. I've had 2 S/C Autobiography models, one 2010 and now a 2011. The 2010 didn't have adaptive or forward alert. The 2011 has both. |
As per MZ's post - they may be an option - My 2010 VSE has them but not all I guess. Ash
The car im looking at has adaptive cruise as per the build sheet, but lacks those 2 switches for controlling the gap. Would that make any sense |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
Are you sure the buttons are not there because if you sit in the normal driving position they are not really visible without leaning to the left, they are almost hidden behind the other buttons and you can soon miss them Agueroooooooooo. 93-20
