![]() | Home > Technical (L322) > Electric motor for steering wheel |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
Cant really help Mike but sounds like the culprit, if you can, do a check with the old voltmeter on the battery after turning off, but the steering wheel motor would do it Happy Holidays |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
It would be very wise to read up on here about the steering column motor, as it's a whole assembly, and very expensive, when at the dealers. There are a few solutions, one, to address, a nylock nut, that unscrews itself, and then the motor can't find itself....
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
Mine is starting to annoy me with its random leg crushing escapades , so I've been doing a little research ..
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 392 ![]() ![]() |
Thanks All! John, on the 2008, is there a way to disable the auto retract? I know there is on my 2011 but I looked thru the manual for the 2008 and I couldn't find anything?? Thx! mike |
Through the diagnostics port .
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
Might this be him? http://www.ebay.co.uk/itm/Range-Rover-L322...Sw5ZBWM861 |
Hi John,
I have the 2002 model. I know it works for up to 2006, within a menu on my diagnostic tool, with the other links, like double locking, and alarm chirp, you can switch off auto steering column action. I can still use my adjust action, with the the lever, and I'm sure it would still work with the the seat button memory, for another driver too. -mine was doing a few odd things, when I got the car, and I read here, that the early models, can be turned off. Perhaps mid-term models have it slightly similar. But I couldn't do it without a diagnostic tool. ( mine is RSW allcomms).
Reecy Member Since: 02 May 2015 Location: Southport, Lancashire Posts: 56 ![]() ![]() |
Hey up,
