Home > Duckworth Parts > Door cable inside
Eirik34
Norway
Door cable inside
Hi Dan, when operating the inside door handle on the driver side, I get a feeling that it will snap in the not-too-distant-future... I do not, however, get the same feeling when using the external handle.
I see that you have the "Range Rover External Door Release Cable Part No.: FQZ000041" in stock, but do you also have the inside door cable? I think it has the part number "LR011173", but I'm not sure. Would you recommend changing the external cable at the same time?
This is for our L322, 3.6 TDV8, MY 2007, left hand drive (Norway).
In addition I'm increasingly getting the IID tool message "0x30 Air quality sensor line fault ", and I therefore consider changing the Air Quality Sensor (ref this thread: http://www.fullfatrr.com/forum/topic28100....y+sensor). Do you have the part "JTF100130" as well?
I will also need some oil-, air- and pollen filters.
Post #364187 28th Dec 2015 9:19am
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Mine has just snapped....
Big Cry
Post #369787 31st Jan 2016 6:59pm
