Home > Maintenance & Mods (L322) > Water Digress
Barrie Springthorpe
England 2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Water Digress
I seem to have a slight leak on the rear n/s back window, it has stopped the satnav from working and the dash display has changed colour. I`ve been advised to wrap my electrics in plastic bags which I`ve done , once I`ve stopped the leak do you think there is any chance of drying the area out and restoring everything, regards Barrie.
Post #364234 28th Dec 2015 4:01pm
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Depends how bad the water ingress, you will need to remove all units and where able open up and clean all the boards, brake fluid is good
Then get some Pcb protection spray once spotless and checked and seal them for future protection Thumbs Up
Items in the boot are plug and play so you can replace with others if found to be toast Thumbs Up Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #364236 28th Dec 2015 4:45pm
Posted in the wrong section - unless you're just bought an L405 Wink
and its 'ingress' - searching on that will give you a few threads like this one Thumbs Up
Post #364237 28th Dec 2015 5:01pm
Barrie Springthorpe
Water ingress
Thanks for putting right,
Post #364284 28th Dec 2015 9:17pm
