![]() | Home > Maintenance & Mods (L322) > Supercharged jaguar engine |
| robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467
Try a oil engine internal flush, and a new oil pump on the engine, it will be getting tired.
| Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217
Thanks for the info .
Recommend doing all at once as full tracking and camber is required, that's about another £100 cost...
It it having both sides done at once , I just worded it wrong .
Yes it's the load arm for travel front to rear and lateral support, but would just drop the lot and replace all at once or the new tension will put more heavy load onto the original arms left..... Can make the handking scarey in this occurrence Current vehicles
Ok thanks .
Tops are pre-mounded rubber with steel inserts and centre bearing retained within it, does all the work of steering and takes all the knocks through the suspension |
| kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335
Are the top mounts on these separate or part of the air strut? Ie can you replace just the top mount? |
ThAts a question I was asking myself yesterday .
So are you saying the top mounts aren't separate items? |
Yes from what I found .
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885
Top mounts are a separate part, and around £40 each.
Likewise, I can't seem to find separate top mounts. I wanted to do them as part of a general front end refresh - my supercharged has done 198k |
Hey Mikey , that's great news !!!
