![]() | Home > General > Hello - potential owner after a bit of advice! |
sagalout Member Since: 30 Dec 2015 Location: Harrogate Posts: 22 ![]() ![]() |
Hi there, just popping over from the RRSport site. Had mine for nearly 3 years now. Love the car and do a bit of offroading in it. In fact I've since managed to get some Bowler 18" wheels with Cooper AT tyres which make it remarkably capable.
Ah thanks - that's a lot better than I thought! I saw a photo which suggested there was a big lip between the boot and the seat, but that photo looks fine.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
Don't know on the range for the 405 as I have a 4.4 L322 but I'm sure someone will be along with an answer soon |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8115 ![]() ![]() ![]() |
I've got a 4.4 SDV8 - and a fairly heavy right foot - but I still get 550 miles to a tank - something like mid 90 litres at a fill |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1424 ![]() ![]() ![]() |
If your focus is on practicality then you might consider a late 322 with one of the engines you specify. It has a much larger boot due to the higher roof and the seats tumble as well as fold. The 19" wheel option takes 255/55R19 tyres and there are a number of all terrains available, the Goodyear Duratrac being the LR homologated choice. They have a relatively soft compound so work quite well in snow and on ice as well as on mud/soft ground but will not be as sturdy as an MT/R. If you are on sharp rocks a lot they will cut more and the sidewalls are not as strong. You will have a bit more weight with the 322 than what you have with the RRS, but I think it lifts higher for better obstacle clearance/articulation. I think LR pitched the 322 as more off road capable than the RRS, but as you say tyres are crucial.
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
I get over 550 miles out of my L405 SDV8. The range at fill up is always around 600 miles (but you fill up short of that.
Thanks for the replies.
