Home > Technical (L322) > Rear suspension dropped on return from holiday!!
dvb247
United Kingdom 2006 Range Rover Autobiography 4.2 SC V8 Bonatti Grey
Happy New Year All
Just returned home from a 2 week holiday and noticed my car had dropped 3 or 4 inches at the rear, started it and set the car back to drive height, turned it round and parked it up, all looks fine again.
had the L322 a couple of weeks and had the compressor replaced under warranty by my local garage just before my holiday, didn't notice it dropping before my holiday but then I have not left it for 2 weeks since I have really only owned it just over a month?
Could replacing the compressor cause the rear to drop? or maybe has been sold to me with a slow air leak?
Post #364789 1st Jan 2016 3:05pm
Start looking for leaks in all heights , continuously running the compressor because you have a leak somewhere will quickly knacker it . 2008 MY Supercharged
Post #364856 2nd Jan 2016 2:06am
dvb247
Would there be a hissing sound?
If it is seeking, its about an inch a week, not detectable if the car is used daily??
Post #364891 2nd Jan 2016 1:25pm
could be a small pin prick, use very soapy water when in off road height.. ... - .- -.
Post #364892 2nd Jan 2016 1:27pm
dvb247
where? round the compressor in the boot?
Post #364900 2nd Jan 2016 2:10pm
the four airbags.... ... - .- -.
Post #364908 2nd Jan 2016 4:05pm
dvb247
will do Stan thanks, you don't suspect the new compressor fitting then?
Post #364910 2nd Jan 2016 4:16pm
could be anything thats leaking..start at the airbags and work your way back [pipe work/air tank under car] to the compressor.. ... - .- -.
Post #364911 2nd Jan 2016 4:21pm
