Home > In Car Electronics (L405) > Voice Output For Txts With Bluetooth?
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
I noticed on previous loaners, one a Disco Sport and the other a 15 plate Evoque that when I had a call and I didn't take it the vehicles voice system would tell me if I had a voicemail and it would give me the option to listen to it or ignore it, is that a recent change to these systems or specific to those models / years?
My 13 plate SDV8 doesn't seem to tell me that, it does tell me the person calling if its a stored contact but says nothing about the voicemail etc. is this something a software update can sort?
Thanks
Carl
Post #364571 30th Dec 2015 10:31pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Hi, my Range Rover (L322) gives me options to either read out and reply to texts or ignore reading out texts. Not sure about missed calls, only comes up with missed call on the sat nav screen. Not sure if it's to do with the actual phone itself. When I had an iPhone 5s it didn't give me those options but I've now paired up a windows phone it gives me the read out options. Hope that helps a little.
Post #364576 30th Dec 2015 11:08pm
carlos50
Just noticed no CD track, artist etc info either, pretty bad when cars a tenth of the price show this, does your L322 show this info?
Post #364830 1st Jan 2016 9:52pm
Basilfawlty
England 2016 Range Rover Autobiography SDV8 Corris Grey
Mine has all the track info
Post #364841 1st Jan 2016 11:47pm
Lad
Carl, no I don't think mine does. Not looked for a setting to display it if there is one. I'll look next time in car. Most of time I listen to the radio.
Post #364851 2nd Jan 2016 12:44am
Emperor Mong
On Text: if iPhone, set up "Hey Siri". Have phone plugged in. Ask siri to read texts.
On display: It doesn't when it's via bluetooth (in the main dash display between the dials). A wired connection does.
Post #364852 2nd Jan 2016 12:55am
carlos50
I'm using a Nokia Windows phone, it gives that option with the newer LR's I drove?
The CD I played was a genuine disc from a shop inserted into the slot in the dash, it just says CD and the track no I the display in the instrument cluster and the main display in the dash?
Perhaps there's a software update available?
Post #364880 2nd Jan 2016 10:41am
Emperor Mong
I have never used a CD - always an iPod with around 6000 tracks on it. I think you need to have CD text on the CD for anything other than the CD number and track number. I can burn those from iTunes.
Post #364901 2nd Jan 2016 2:29pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
If it is a new CD, it will just list the tracks with no information as I assume the Gracenote software will not yet be aware of it. I have this on a couple of CDs I bought and uploaded via the CD player onto the hard drive in the car , they just show as CD 8 and CD 9 and not info. I assume thaat hte Gracenote software is updated every so often via dealer or radio carrier signal? Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #365192 4th Jan 2016 7:38am
carlos50
Yes, that could be it, when I inserted the disc it said something about Gracenote, never heard of it before, Embarassed
Post #365221 4th Jan 2016 12:13pm
Lad
Mine just says track number. But mine is an old model. Just wondering if it could be updated to show more info?
Post #365326 5th Jan 2016 12:56am
RRVSE
Not sure , depends whether your head unit can have the Gracenote software added, I suspect that if you don't have it already, it won't just be a software update. Also, from the amount of CDs I've now converted to MP3, I am surprised at how often the Gracenote software gets the track titles (and sometimes albums) wrong and even though I have got the correct artist/song/album saved against the track on the USB stick, the Gracenote overrides this with what it thinks it should be , it's probably around 85-90% accurate. Steve
Post #365501 5th Jan 2016 10:03pm
RRVSE
duplicate entry of above - removed Steve
Post #365502 5th Jan 2016 10:04pm
Lad
Ta, I've never tried mp3's. I was thinking other day to put some mp3's on a DVD, would they be readable? Can't remember if the disks are + or - disks, and would that matter?
Post #365555 6th Jan 2016 12:11am
RRVSE
Not sure, when I had my L322, I put hundreds of MP3 on a CD and the head unit showed the artist/song names that I had defined on each track. If I remember though, I found a limitation as to how many MP3 would be recognised under a folder listing, so subsequently broke them down (as I just put loads together on the CD , not albums). I think the drivers manual said something about this but gave no information as to the amounts. I think the basic cure is to create quite a few subfolders so that you never exceed the track limit. Not sure about the DVD as I always just used CDs (as no video involved). Steve
Post #365622 6th Jan 2016 1:13pm
