![]() | Home > Maintenance & Mods (L322) > Coolant Low |
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3964
Just pumped most of the water out, conveniently (as I haven't driven it) it was still sitting above the rest of the coolant and refilled with 50:50 mix. No water under the car this morning soi I'll just keep an eye on things and see how it goes its probably not quite 50:50 overall as there was a bit of water I couldn't get too but I don't really need protection down to -32F |
| RaveRover Member Since: 14 Mar 2017 Location: Melbourne Posts: 36
Hey.
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3887
Geoff,
Mine turned out to be the pipe that runs front to back in the "valley" between cylinders. Got it fixed but it wasn't cheap. Geoff |
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
RaveRover, use of distilled water is primarily to prevent buildup of calcium deposit in the cooling system. use tap water in emergency only and reflush system as soon as possible. |
| All times are GMT |
